Hi!
Thanks for letting me join this forum
I have a Mini Se and whenever the temperature goes below zero the small pin on the left side of the receptacle for the charging cable freezes. This means I can't drive away.
I typically put in the cable when I come home from work in the evening. The car is parked outside. When I'm going to work in the morning the cable is stuck and I can't drive away. The only remedy I've found is to bring out an electrical heater and heat the receptacle until thawed.
Has anyone on this forum encountered the same problem and have you found a solution. My garage checked with BMW and learnt it was a known problem and nothing else.
Temperatures dropping below zero is quite common in Sweden
Thanks for your support
Olof
Lund, Sweden
Olof
Lund, Sweden
