SAM1130
Unfortunately you cannot adjust the volume of that obnoxiously loud beeping.Well, that makes sense...the 2019 level is not an issue...no way to lower the volume rather than turn it off?
If I'm not mistaken the nature of a rheostat means that it can adjust the signal or "gain" per se in a positive or negative nature. Thus the ideal location for this would be inside the cabin of the vehicle. It is my understanding that as of right now the location of the necessary wire to do this is unknown.Back to the sound, would a rheostat in the circuit feeding the speaker allow you to alter the volume without turning it off...that might be the best of both worlds. the sound in the 2019 is not obtrusive.
I was just curious, is there any way to pop the grill out to get to the plug?I did a lot of searching and could not find this for 2020 models, so I decided to tear apart my own Niro EV which I got about two hours ago. Here is how to disable VESS on the 2020 US model.
For the faint at heart: you have to partially remove the front bumper cover and it is a pain in the rear to put back. You will probably scratch the bumper cover around the lights like I did. I followed the guide here: http://www.kniro.net/front_bumper_cover_repair_procedures-1473.html
1) remove the 4 10mm bolts from the top support above the radiator.
2) remove the 1 8mm bolt from the wheel well.
3) remove the numerous tabs (4 in the wheel well, I think about 8 along side the bottom of the front of the car) - use a screw driver for this.
4) pull up and out around the light to release the cover.
5) unplug VSS wiring harness (see pic)
6) put everything back by going back to #1 on this list.
Yes, read the first post in the threadI was just curious, is there any way to pop the grill out to get to the plug?
Interesting, and thanks for posting. What year and trim is your Niro?I confirmed the wiring harness is accessible from the engine compartment and you don't need to take your car apart. I used the OP's photos to identify the VESS speaker (purple sticker on top). My photo was taken just under the hood latch, from the perspective of the engine compartment looking forward to the front of the car. A long screwdriver could be used to depress the tab and then lift up the harness.
Tested, and I can depress the tab with a long screwdriver (approx 10" flathead). Did not disconnect, as I'm holding out for a non "all or none" option.
Also, found this schematic on KiaPartsNow.com. Part A is the speaker.
At one point you said you could register and purchase the service manual. Do you have a link for that? Interested in doing this...
It is probably by design, just as Kia has made it progressively harder to disable this system without disconnecting it. For example, it was discovered that 2020 US Niros don't have the wires in the harness to support the factory VESS disable button. Nor is the control module accessible from behind the glove compartment. I think it is beyond stupid that US spec cars don't have the VESS disable button. It's probably yet another dumb government regulation to make someone feel good about themselves or to justify their existence. Personally, I pulled off 1/2 of the bumper cover and unplugged the VESS module. Fortunately, Kia hasn't gotten around to having a VESS-specific message show up on the dash nor a CEL shown. That's probably going to get fixed in 2021 models. LOL!
Hey there! I unbolted everything and removed all the noted tabs but having a hard time removing the bumper. There’s a part that gets stuck near the front headlight - any tips for getting the bumper off?Agreed. This is very likely programmed into the firmware that runs inside the VESS module itself. The mothership only sends the speed and gear selection values to it and the VESS takes it from there and annoys everyone with it's horrible sound. LOL!
I realize it's much easier to ask for something than to just do that something as it takes time and money. My post was merely trying to stoke some ideas and perhaps give a direction to the project. While I have an IT background, it is not in hardware. I'd spend hundreds of dollars in tools and equipment and many hours of time learning to come up with a solution that someone else already has the tools, equipment, and experience, such as yourself, to do this kind of work.
For now, I spent about 1 hour carefully taking off my bumper cover and disconnecting the VESS. It's been several days and no CEL or other message has shown up. I plugged in my ODBII reader to look for DTCs and nothing even came up there, but a dealer scan tool would be more thorough. So unless a tech notices the sound missing at the dealership and makes a note of it, they may never know there's a change.
Quick note on bumper cover removal: you do not have to remove the entire bumper cover. It is bulky and unwieldy for a single person, so just leave one half of it connected to the car. That still leaves you plenty of room to disconnect the VESS.
That all being said, the sound of near-silence when backing up or going forward is golden.
