OK, then... That implies the 'buffer' is more like 25% (maybe 10% at the bottom and 15% at the top)?
I agree there are charging losses. The confusion factor to me is exactly how these losses are booked.
Is the specified 17 kWh rated capacity just the ideal battery itself, or is it the entire 'system' with the plug (and any charging losses) as the reference point?
I suppose it seems more likely that there is actually a 17 kWh battery, and my initial full charge is only filling it to 13 kWh (the other 4 kWh being the 'buffer').
However, I am pretty sure that the EPA rating (kWh per 100 miles) treats the vehicle as a black box and measures the energy input to the plug. This means that charging losses are embedded within the EPA number...
My basic point remains...
The vehicle itself has measured a 10% drop in battery capacity. I have observed a corresponding 7% drop in the 'full charge' input energy. These two are plausibly close, but you may speculate as to what happened with the missing 3%. The vehicle could have altered it's buffers, or being within 3% could just be measurement tolerance somewhere in these numbers. How the buffers get used (or not) as the battery degrades over time is a Honda mystery. Maybe we can figure it out over time.
Do you have any theories about this 3% discrepancy? I am fairly happy to have a result that is only 3% off (3% of a ~50 mile range is only 1.5 miles after all).
The specified battery size is calculated by nominal voltage x Ah. Battery capacity is not a constant, but a variable that will go up or down under different conditions (degradation is a permanent decrease and a separate issue). The major factors that influence change are temperature and discharge rate.
Here is an example of how a battery rating is derived (this is for an LG 21700 cell, but the same type of rating/testing is done on al Li Ion batteries):
4.1 Standard Test Condition
4.1.1 Standard Charge
Unless otherwise specified, “Standard Charge” shall consist of charging at constant current of 0.3C.
The cell shall then be charged at constant voltage of 4.20V while tapering the charge current.
Charging shall be terminated when the charging current has tapered to 50mA. For test purposes,
charging shall be performed at 25ºC ± 2ºC.
4.1.2 Standard Discharge
“Standard Discharge” shall consist of discharging at a constant current of 0.2C to 2.50V. Discharging
is to be performed at 25 ºC ± 2 ºC unless otherwise noted (such as capacity versus temperature).
Both the amount of energy available from a battery and the amount of energy to fully charge it vary with temperature. +/- 3% in non laboratory conditions would not be unusual.
As an example, the above 21700 specs:
-10℃ ≥70% of Wh
0℃ ≥80% of Wh
25℃ ≥100% of Wh
55℃ ≥95% of Wh
The method that Honda uses to assign the Ah number is different than a discharge test and likely embedded in the BMS. It's accuracy will be different than a charge/discharge test under lab conditions, but will still give a good "over time" picture of battery health. I don't know the specific method that Honda is using, but that could also account for the theoretical number generated by the BMS (or other test equipment) and the "real world" number you are getting.
Battery buffer is a bit harder to define, but it is extremely unlikely they are playing with those. The battery capacity test shows the charge voltage on each cell. IIRC, it appears the target voltage is 4.1, and it is a fair assumption that the cells rated max voltage is 4.2. SOC% should be measured in available Ah, so that would be derived as the area under the curve as the voltage drops at a set discharge rate over time. There is a fairly quick voltage drop under load (the higher the load, the more severe), so defining the upper buffer can be difficult, but a 90% SOC will correspond to a cell voltage of around 4.05 (varies some by the actual cell characteristics)
If you look at the pink line (the specified .2C discharge rate for this cell), and look at the where the plot crosses 10% of the total Ah (~500) you can see the corresponding voltage.
The bottom buffer is harder to define as it is a bit "squishy" in the Clarity PHEV. The car fires the ICE even when there is still some charge available, and under certain conditions it will dip further into the battery.
