Got about 1000 miles on the car so far and started noticing a rapid tapping, creaking, or rattling noise coming from the drivetrain. I only hear it at very slow speeds (around 10 mph) such as navigating around a parking lot. After doing some experiments, I have come up with the best steps to reproduce it:
1) Turn off regen by pulling the right paddle until you see regen at level 0. This allows the vehicle to coast without any automatic regen braking applied so that it will stay at constant speed when you let go of the accelerator.
2) If your version has the option to turn off VESS, please turn it off so the artificial engine sounds don't interfere with the test.
3) Accelerate to about 15 mph and then let go off the accelerator and brake pedals, allowing the car to coast.
4) As the car slows down to about 5-10 mph, I begin to hear this noise.
5) If I turn the gear selector dial to Neutral, the noise instantly disappears. This confirms it's not coming from the wheels or brakes. My best guess is that it's coming from motor or reduction gear.
I have attached a recording of the noise. You can hear me accelerating to about 15 mph several times and then letting go off the pedals to let it coast. The tapping noise begins at a certain speed and then slows down in frequency as the car decelerates down to 5 mph.
Can some other owners try this test so that I can confirm if this is normal on this model or some kind of defect? Please don't vote unless you've done the testing using the procedure I outlined or have already heard the noise during your regular driving. Thanks.
