FloridaSun
I queried my VIN and there is a battery repair recall now for my VIN..
Nothing on the Canada website for mine ... yetI queried my VIN and there is a battery repair recall now for my VIN..
According to this website my VIN is not affected.UPDATE for Canadians:
Transport Canada now lists the recall #2020-477
https://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng,eng&mk=3759!39386&mkName=HYUNDAI&md=KONA EV&fy=0&ty=9999&ft=&ls=0&sy=0&syName=All Systems&all=0&rn=2020477&cf=SearchResult&pg=0
Issue:
"On certain vehicles, there could be problems with the high voltage battery that cannot be detected by the battery management system (BMS).
As a result , the high voltage battery could short circuit after it is fully charged."
Safety Risk:
"A short circuit in the battery could cause a fire."
Corrective Actions:
"Hyundai will notify owners by mail and instruct you to take your vehicle to a dealer for inspection. The high voltage battery will be replaced, if necessary. The dealer will also update the BMS software to better detect battery problems. Hyundai recommends that you should park your vehicle outdoors, and away from other vehicles or buildings until the recall repairs are completed."
Well in my case I can park outside but not away from other vehicles or buildings at all times, so I guess I will be limiting my charge to 90%, until this is resolved.
Note the Hyundai link still shows no recalls
I have an early build (Dec. 2018) so that might have something to do with it, at least according to the prevailing scuttlebutt. BTW I've also had the BMS update done.It is possible the Canadian Hyundai website does not indicate a recall for one of two reasons:
(1) behind in their postings
(2) Hyundai is aware my Kona EV had the Campaign 960 done (which is probably the BMS update required in the recall) and has passed battery inspection for cell deviation and insulation resistance. If this is the case, a letter telling me that would be nice so I can sleep a little better, also have no fears about charging to 100% on occasion.
Took a bit of digging, but I found this post showing we received our cars within 2 days of each other:I have an early build (Dec. 2018) so that might have something to do with it, at least according to the prevailing scuttlebutt. BTW I've also had the BMS update done.
Interesting , I have to wonder what the inspection process entails, surely they are not going to crack her open and have a look see?
Hi truly hope that other than checking and potentially replacing the battery, Hyundai doesn't pull something off like reducing the actual maximum usable capacity of the battery to "fix" this via a software update (as in ; make the 100% charge a "lower than before" 100% charge).
I'm in Canada ; nothing showing up for my VIN yet but 4375 vehicles affected (model year 2019 and 2020) this is probably a majority of the 2019-2020s...
Are you in Canada? I can't recall such an early build date for other Canadian customers.For the moment I just think Hyundai's website is not updated.
For the BMS update, it never showed there for me but I received a letter. Mine was built in Nov 2018, let's see what happens next.
In the UK website there are people with appointments already so we should have more information soon
Hopefully not, I for one will be getting an OBD2 right away and monitoring battery stats moving forward and post recall/update. Call me paranoid but I don't know ; have a bad feeling about this one.Can they legally do this? Or can they do this and give a small compensation and we just have agree?
I am, I think I got the second car that came to MontrealAre you in Canada? I can't recall such an early build date for other Canadian customers.
Noting this is entirely speculative, the combination of multiple connection points of the cooling pipes inside the housing, green coolant in earlier models with what we understand to be some level of conductivity, and mostly the very, very low percentage of the events is intriguing.... if they did crack it open, what would they be looking for?
I guess that is the crux of the problem nobody really knows anything and Hyundai is not sharing. I kind of suspect vagueness from Hyundai is because they really don't have a great plan. In the end its all pure speculation. Call me jaded but I will just wait for some brave souls to be the first recall volunteers and report back before I consider letting them touch anything.Does anyone know what the recall actually entails? Are the reports of reducing battery capacity via software true? Is it just an inspection of the pack?
That I doubt - if they did crack it open, what would they be looking for? The easiest thing is to check for cell groups that are unbalanced - they can do that with software (just like we do with TorquePro or SoulEVSpy). And there is a 2nd impedance check that they can also do to look for ground faults. Maybe something else??
