Nelson1994
I did a lot of searching and could not find this for 2020 models, so I decided to tear apart my own Niro EV which I got about two hours ago. Here is how to disable VESS on the 2020 US model.
For the faint at heart: you have to partially remove the front bumper cover and it is a pain in the rear to put back. You will probably scratch the bumper cover around the lights like I did. I followed the guide here: http://www.kniro.net/front_bumper_cover_repair_procedures-1473.html
1) remove the 4 10mm bolts from the top support above the radiator.
2) remove the 1 8mm bolt from the wheel well.
3) remove the numerous tabs (4 in the wheel well, I think about 8 along side the bottom of the front of the car) - use a screw driver for this.
4) pull up and out around the light to release the cover.
5) unplug VSS wiring harness (see pic)
6) put everything back by going back to #1 on this list.
