K-Ken, how do you know that your mileage is different? I have yet to figure out my mileage when in hybrid mode since there is no way that I have found that I can track which parts of a drive are using the ICE and which parts aren't. In the 10 weeks that I have been driving my car, I have only filled the tank once. That was at 1680 miles and it took 5.4 gallons. I know I wasn't getting 311 miles per gallon in hybrid mode.I infer from the way my car acts that this is not the case due to behavior noted above and the fact that my mpg is different.
The only time I have ever driven beyond the EV range is my drive to work. It is 35 miles one way, but I only go to work 3 to 4 times per month. I tend to arrive at work with between 8 and 10 miles of EV range, so the return is about 25 miles in hybrid mode. My drive to/from work is 95% highway in relatively flat country (I live in central Indiana). I observe that the ICE comes on just after the EV range gets to zero, and then it cycles from low RPM to high RPM to shut down according to the needs of the car for motive power. Yes, there are times when only the battery is moving the car, even at highway speeds and no EV range indicated. Sometimes the engine and the battery show as motive force, sometimes the engine is the motive force while simultaneously charging the battery.
In other words, my Honda Clarity behaves just like any other hybrid powered car when the battery is discharged down to zero EV range. Sometimes ICE power, sometimes battery power, sometimes both.
One thing I know I WON'T do is an experiment to drive the car without charging it to test the ICE mileage. That would be the only way to truly determine what my mileage is in either city or highway driving. I bought this car to drive as much as possible on electric power. If I had wanted to drive it only as a hybrid, I would have bought the Accord hybrid when they came out. Which was my plan until I stumbled across the Clarity.
