5kg.
Toyota says that the Mirai fuel tanks hold 122.6 litres. But hydrogen fuel is sold in $/kg. Typically pressure is 70Mpa or 10kpsi. So how many kilograms of H2 fuel does the Mirai hold?
...the line states that the combined weight and 5kg. So why would you assume the word "combined" applies only to the weight? Second although there is a citation for the weight, there is no citation for the 5kg. I think it is just a common mis-conception.
Thanks. Although I still stand by my calculations it appears that the practical (useable) limit is 5kg. I did spend a little time trying to find out the minimum pressure, but only found out that there is a pressure regulator (reducer) between tank and fuel cell as expected but no value on what it reduces to. Also the incoming air required to get oxygen has a compressor which I assume brings the oxygen supply up to the same pressure as the regulated H2. In any case it is difficult to imagine these pressures are very high, that is it would require a minimum pressure of 10k/(7.5/(7.5-5))= 3,333 psi to support my theory. An admittedly unrealistic minimum pressure so I still don't have a reasonable explanation for the discrepancy.Here's a report by someone actually filling up a Mirai.
?? Range is supposed to be about 320 miles. But I don't know why you are even considering buying an FCV. Oh but I suppose leasing is a good deal.Having looked into this vehicle, the answer is not enough to get me from the station by my work to the next closest station, making it useless.
I am not, I looked into them when they were offering a free FCV for those that lived or worked within a certain distance of a station and considering the station was right next door to my work, it was worth checking out. 320 miles is decent; however, it means a cross country trip would be out of the question, but our new Kona could do the trip we just did in our CMAX for less money and no extra time added to the driving.?? Range is supposed to be about 320 miles. But I don't know why you are even considering buying an FCV. Oh but I suppose leasing is a good deal.
