craze1cars
All good! We all gots our heels dug in firmly! Agree to disagree. Everyone fuel up and drive!!
Finally, my point is that unlike my VW, with Clarity even 5 HP can make a difference, because the engine power is so marginal when you climbing. So it worth experimenting if someone has the means to test it.
I may be worth it to you.
A maximum power the ICE isn’t even directly powering the wheels. It is spinning a generator that sends electricity to the traction motor. You could fuel up with 100 octane and install a nitrous tank, just don’t expect any more current to come out of the generator. The traction motor is rated at 181hp. It is powered by electricity. This is not a conventional ICE vehicle.
Is any of this sinking in?
You’re not going to get an additional 5hp out of this car. Maybe you know more than the Honda engineers. Maybe you’re the only one willing to spend time and money on premium fuel and dyno testing to find out that the Clarity is a hopeless case.
Keep us posted.
I enjoy threads with titles including gas type or oil type. I get out the popcorn and lemonade and enjoy the repartee.![]()
No the best way to maintain power is put the car in HV Charge, preferably before the climb, and let it rev. Even if you do it during the climb you'll do the best job the car can of maintaining battery charge. I charge my car exclusively on HV Charge, never plug it in, and it works great. Been getting 51-52 mpg the last few fill ups.Yes, I think this is a good way to drive up very steep climbs. You want to force the engine to run but at the same time use some battery to supplement engine power. I have to try it on a real climb and see how much battery it will use.
The ICE drives the generator. The generator has a limited output capacity. A more powerful ICE would not increase that capacity. Output is RPM dependent. If the engine can obtain peak RPM to drive the generator to peak output on 87 Octane, that’s all we’re going to get.
Assuming the generator is perfectly matched to the engine output and has no headroom (I don't believe it is the case), still you will get lower RPM from the engine, which is basically what I am trying to achieve here.
You'll just go slower.
Lower RPM’s from the ICE will result in less output from the generator.
Does this generator have fixed excitation?I see your point, that would be true if the generator had a fixed excitation, but that would be too limiting, I assume the generator can regulate output, so depending on engine torque it will adjust resistance. Otherwise it has to be regulated for the weakest engine operating condition (lowest torque) which doesn't make sense.
The output of the generator does seem very constant at constant RPM. I see that when the power screen switches from charging to discharging, compared to the power required for driving. It is consistently at the same point of the power meter.I see your point, that would be true if the generator had a fixed excitation, but that would be too limiting, I assume the generator can regulate output, so depending on engine torque it will adjust resistance. Otherwise it has to be regulated for the weakest engine operating condition (lowest torque) which doesn't make sense.
