Checked Canada Hyundai site- no recall listed s/n KM8.......022465 ( manufacture date Dec 22/18), even though the driver dash display has twice gone black.Check your VINS in the Hyundai USA/Canada/your country's website because there's a recall, heat pump for places that have it. Campaign: driver dash display replaced because it can randomly go black.
Sadly,Hyundai is making owners go into the dealership.Only get the fix if Hyundai applies it to your VIN.Since you've had the displeasure of having it happen twice,hope you got some media backup.What's weird,there doesn't appear to be any DTC?Checked Canada Hyundai site- no recall listed s/n KM8.......022465 ( manufacture date Dec 22/18), even though the driver dash display has twice gone black.
No media back up and have discussed this with the dealer techs. They suspect low 12 V accessory voltage, which was true in one instance but due to the extremely intermittent occurrence, I suspect a software glitch somewhat reminiscent of the cause of the auto regen settings changing defaults on a somewhat similar time base . Its not a "perfect" car, but small imperfections don't bother me as I love what the Kona has to offer compared to what is available at the same price point from other manufactures (at least to this point).Sadly,Hyundai is making owners go into the dealership.Only get the fix if Hyundai applies it to your VIN.Since you've had the displeasure of having it happen twice,hope you got some media backup.What's weird,there doesn't appear to be any DTC?
I'm still puzzled by the difference I found in the TP thread where during driving the aux battery voltage data reported by TP and averaged in Excel settled down to 13.0 V after a few minutes driving. When trickle charging it's 14.7 V average and that was stable over 30 min.... the excessively high voltage that
the LDC maintains. 14.8 - 15 volts really is too high to float a lead-acid battery ...
_H*
I now believe this may have been a function of low voltage on the car's 12v battery. It only happened the day before the battery went dead.If the unlock button in the door handle doesn't work, see if the Smart Key is sitting behind keys, wallet, etc. in your pocket or purse. This is reported to be able to block the signal.
Issue: High pitched whine in regenerative braking mode
Fix: Replace gear drive unit assembly, 4 bolts (flange) and traction motor assembly
https://insideevsforum.com/communit...ission-replacement-at-9000mi.7386/#post-86305
You discovered the real reason WHY you don't charge above 80% on a DCFC! It takes a long or longer to charge from 80-100% as it does 0-80%, and when you're paying the the minute, well, the cost of that last 20% doubles the fee. On a car with only about 80-90 miles range that's extremely expensive to get only about 20 miles more range. On a Kona the difference is around 50 miles, but still, charging above 80% on a DCFC is reserved only if you really really need those extra miles and are willing to pay big for it.Compare with a Nissan Versa Note: 39 miles/gallon highway; gas $2.29/gallon; $4.85/78 miles.
PLugshare example of time based rip off.EA up to 75kW/ $0.15 minute: 40kw Nissan Leaf at 50% will take 1.5hr to charge?! This would be 20kWh for $16.50 USD to go about 87 miles/140km [100% - 175 miles/281km.]. To deter DCFC hogging,free,or payment,idling fees would be fine once an EV gets below 7kW,an in app. warning should go off about 10 minutes before so you can get back to the vehicle to move to L2,or drive on.
That's true, which is probably why I wrote "gear drive"The Kona EV doesn't have a rear drive unit.
I'm launching an investigation into the excessively high voltage that
battery..._H*
