Some CAN fun
Discussion in 'Hyundai Kona Electric' started by hobbit, Mar 7, 2020.
  1. hobbit
    hobbit Well-Known Member
    Today I put a quick temporary tap on the P-CAN bus, just to see what's
    going on in there. Most of the buses arrive behind the gateway module
    [the beige thing which also holds the interior fuse block] on a single
    small connector with a short leash to the harness. Not easy to get hold
    of to gently strip a wire and get a miniclip onto it, laying half into the
    footwell with just enough room to move my hands.
    It's a little messy as my grounding probably wasn't the best, and I was
    only looking at CANH and not in differential mode. The bus is quite busy
    as we'd expect, with a whole range of IDs from low 1nn up to mid 5nn.
    All 11-bit IDs as far as I saw.
    The scope was able to capture a couple of "event table" packet dumps,
    but making any sense out of it is likely for another day, if ever, and very
    different equipment. I'll bet that many of the OBD2 figures we have to
    specifically ask for just fly by here all the time in different formats.
    _H*
  2. In case you haven't seen these, Eric Reuter in the Boston area tapped into the P-CAN bus used by the gear selector to bypass the gateway, I assume unterminated. He built a prototype VESS replacement, and as far as I know no one else has explored any further. I bought a CANable USB transceiver to look at this stuff as well but haven't had the motivation yet.
  3. hobbit
    Huh... if he's in my area, I should probably try to hunt him down
    for a bit o' geeking. I can certainly answer his gateway question.
    _H*
  4. He's an acoustics engineer. I believe he lives in Kittery.
  5. Eric Reuter
    Eric Reuter New Member
    Hey guys. I'm here if you need me. I haven't done much on this for a few months.
  6. hobbit
    I wanted to find out if the OBD2 queries are passed directly through to the
    P-CAN bus, so I got the scope back on it. With the car powered up for real
    the bus is a lot busier, as we'd expect. There are several things to learn
    from this trace. It's in dual-view mode, expanding a small segment of a
    long capture into the main window.
    The trace is a lot cleaner, and I believe I know why. Again, I'm only looking
    at CAN_H, the positive-going half of the differential pair. Both wires sit
    at about 2.5 volts in the "recessive" state when they're not sending traffic.
    To send a "dominant" bit, CAN_H goes up about a volt and CAN_L goes down,
    so the voltages fly "apart" and back together. All of this is floating
    a little above ground, and when all traffic ceases the bus wires settle back
    down to slightly above ground level fairly quickly. Thus there is always a
    tendency to drift back toward ground level, and with a relatively inactive
    net like in the previous trace I believe that's what causes the lower-edge
    loopiness relative to the car's ground. With the car fully on/ready and
    *all* the ECUs online and participating, we don't see that so much.
    What we do see, though, is a different voltage effect. At the end of every
    CAN packet is an optional ACK bit, which any receiving device is free to
    send if it likes. Multiple devices can ACK at the same time, and with all
    those participants at once asserting the bus against the termination, the
    voltage for that ONE interval winds up going considerably higher. Then
    everybody waits for the required 20 microseconds or whatever it is.
    The next event is more subtle, notably here over the "524". CAN IDs are
    also priority selectors, with the lowest ones taking precedence. The bus
    arbitration is rather elegant: since a dominant, asserted bus [high in this
    case] is a zero bit, not a one, whichever device is sending the lower ID
    MSB-first is going to hit a zero bit sooner and assert the bus when another
    one is letting it go. When the other device sees that something else is
    sending a lower ID, it stops transmitting immediately and waits to retry
    later. The rest of the intended packet flows undisturbed, with receivers
    basically unaware that any contention happened at all.
    But again, that means that two or more devices *could* begin transmitting
    at the same time, so for a short time we have multiple senders yanking on
    the bus, cutting the effective source impedance by half, or a third, or
    however many tried to speak, all against the line termination. Thus, the
    voltage sails higher until the losing device sees the other's dominant
    bit and shuts up. The ID 524 packet must have won out over another with
    a similarly high ID, so it took a few bit times to resolve. The 220 one later
    took precedence within one bit time.
    The string of zeros across the center has a sprinkling of ones; those are
    the required "stuffing" bits which actually lengthen the packet's duration
    a little. The rule is, any five consecutive bits the same must be followed
    by one of the opposite polarity, to keep receiver clocks synced and avoid
    building DC bias on the bus. A little bias happens anyway; you can see the
    slightly higher tail after the ACK bits before it settles back down.
    You could almost guess the number of participating ECUs on the network from
    this, assuming their transceivers are reasonably within impedance spec. It's
    also clear that the powertrain bus is busy enough that there *is* a notable
    amount of contention. Imagine the mess if the car had only one CANbus, like
    the Prius or any older car before the advent of packet gateways.
    And to answer the original question, the OBD2 queries *do* show up on this
    bus after passing through the gateway. I'll bet with a little creative
    packet construction and monitoring, we could effectively "portscan the
    firewall" and see what it actually passes through or doesn't. I'm sure
    the D-CAN is as isolated as it is to prevent an aftermarket tool or logging
    widget from jabbering insanely and crashing the whole car. Once in a while
    I would plug the Scangauge back into the Prius and have it immediately
    light the whole dashboard with errors and throw a U code, due to some brief
    instance of a mangled partial packet or bus voltage out of whack at the
    moment of connection. That's the hazard of having your DLC on the live
    critical path.
    The world really is analog. If it moves back and forth fast enough, we
    call it digital. I'll talk about packet contents in another post.
    _H*
    HeadsUp and apu like this.
  7. hobbit
    Since discussions of packet contents are more appropriate to the OBD2 and
    monitoring thread, I've posted the second half of the day's discoveries
    over there.
    _H*
