P0C17 position resolver?
Discussion in 'Hyundai Kona Electric' started by hobbit, Sep 22, 2019.
  1. hobbit
    hobbit Well-Known Member
    Has anyone taken a scantool to their Kona, and found a P0C17 DTC set?
    My cheap Actron flags it as "permanent", not sure what that means. It
    supposedly translates to "drive motor position resolver not learned".
    It appears to be completely harmless [if even true?] and doesn't show
    any warnings in the driver display. And the motor and controller seem
    to know the rotor position just fine, or I'm sure things would be
    obviously unhappy when driving.
    Hyundaitechinfo.com is rather unclear about it, and implies that it's
    a very minor tuning tweak that can be commanded to start by the "GDS"
    dealer diagnostic tool, and then the car's supposed to figure it out and
    perform the tuning by itself by simply driving around a bit. The techs
    at the local dealer never heard of it, and refuse to go pull codes from
    a new Kona on their lot to see if it has the same thing.
    There's a vague reference to Sonata hybrids with the same code,
    + https://www.hyundai-forums.com/threads/p0c17-code.657213/
    _H*
  2. permanent dtc is a hard code, means the fault can't be cleared until the problem is actually fixed. You shouldn't have any dtc come up at all, get the dealer to fix the problem irregardless if its symptomatic or not.
    KiwiME and electriceddy like this.
  3. hobbit
    The story got a little more convoluted, with the folks at HKMC corporate
    calling one of my local dealers and running into a fairly sour attitude
    as far as customer-service. In a call later with a fairly apologetic GM,
    she suggested I bring the car in for a quick go on GDS and they'd try to
    get to the bottom of it. This time, they did their research ahead of time
    and went out to scan another car on the lot like I'd originally asked.
    GDS found *no* codes. It saw the missing VESS of course, and
    something about a weather receiver not present, but not a peep about
    any resolver calibration.
    So mystery solved, and obviously my old Actron scanner is useless
    on this car.
    _H*
