Lumbar support?
Discussion in 'Cooper SE' started by DSN, Aug 7, 2021.
  1. Melinda Mulcahy
    Melinda Mulcahy New Member
    Thanks so much. I've made a little headway, but still have pieces I can't get connected. I've made a video showing the images and explaining the mechanism.
  3. chrunck
    chrunck Well-Known Member
  4. teslarati97
    teslarati97 Well-Known Member
    See if you can hook the wire to the bottom corner of the cage itself (it's the same dark black coating) . You will have to test with the knob for max-min lumbar support to see if you hook in the front or behind?
  5. Melinda Mulcahy
    Thanks. Unfortunately, the casing around the cable has a stopper that limits how far I can turn the knob. Unless the hook is wrapped further around the frame, the cable is too long to tighten the cage.
  6. teslarati97
    Oh for a second I thought it almost fit.
  8. chrunck
    This is making me want to buy that kit. I like a good puzzle...
  9. Tommm
    Tommm Well-Known Member
    in your slide at 55 seconds, about two inches up there is a square box. can you hook it to that. all it looks like you are doing is locking that cable so it doesnt twist. Will that square on the left hold it?
  10. chrunck
    Were you able to make any progress on this?
