Level 2 charging question.
Discussion in 'Clarity' started by M. Shah, Aug 23, 2019.
  1. sniwallof
    sniwallof Active Member
    Just check first to see if the existing outlet (the 6-50 receptacle) can simply be rotated 180 degrees in the same box so the cable no longer covers the 120V outlet. If that can solve the problem, it may even be easier than moving everything to the left, possibly the second option.
    Okay, let's all meet over there for dinner and get this job done! :)
    M. Shah and 2002 like this.
  2. sniwallof
    These are good, this is what I use for large diameter wire/cable:
    https://www.amazon.com/dp/B07V8XLG3F/ref=biss_dp_sa1
    They are relatively expensive, but they are very safe for large diameter wire and do not fail.
  3. MrFixit
    MrFixit Well-Known Member
  4. craze1cars
    craze1cars Well-Known Member
    https://www.lowes.com/pd/Utilitech-WingGard-10-Pack-Blue-Wing-Wire-Connectors/999953602
    40 cents each. Rated for the application, and in stock everywhere. Not sure what else to say to those not in the trade, but these are exactly what most any electrician would grab in a dry and stationary location to connect a pair of 6 gauge wires. Anyone in a home with electric heat and/or electric cooking range or oven most likely has these “Big Blues” in their homes right now. Extremely common...
    Yes there are many other options that cost more and would work equally well.
  5. M. Shah
    M. Shah Member
    Problem solved. I moved my ge wattstation to the other spot and will install the chargepoint to the left. I have already made a 6-50 plug with a 6-3 wire that I connected to chargepoint. I can still access both 110 volt outlets. Thanks for the help. 20190824_074922.jpg 20190822_105021.jpg
    craze1cars likes this.
  6. craze1cars
    Awesomeness that was easy. Funny how now seeing a wide shot as new info my suggestion would have totally failed anyway. That junction box at the floor could NOT have been easily moved at all...that’s where the power feed comes in!!
    So often we don’t receive enough info from a photo that doesn’t show the whole scope of a situation.
    Glad you found an easy fix on your own.
    M. Shah and sniwallof like this.
  7. craze1cars
    I sincerely hope each of those plugs are on 2 dedicated circuit breakers in your service panel. If they share a single breaker this ain’t gonna work....
    sniwallof likes this.
  8. At Home Depot today...
    I used these to good effect connecting large gauge wires to connect a temp pole to an RV pedestal.
    M. Shah and craze1cars like this.
  9. Sandroad
    Sandroad Well-Known Member
    Agreed! We didn't have even close to all the info needed. That second 240V outlet to the left self-solves the problem. I'll bet this is one of the few garages in the country with two level 2 EVSE stations available. Of course the 240V 64A load will "spin the meter" when both are plugged in!
    Rangavasu and M. Shah like this.
  10. sniwallof
    That is funny how different the wide view is, now understanding that the power feed is at that box near the floor.
    It looks fine the way you have it.
    Now seeing the final installation, a possible improvement to consider some day might be to come out of the power feed box at the floor on the bottom to the right, then make a right angle turn (a mirror of the same right angle turn on the left side would work) going up to below the EVSE. (may need to go right or left to be over a stud, probably right to just under the EVSE would be better) (Also, if there are young children, high where it is may be safer.)
  11. M. Shah
    M. Shah Member
    2 separate circuit breakers at 50amp
  12. M. Shah
    M. Shah Member
    Fortunately we don't drive a lot. The leaf is driven 15 miles a day and 50 miles over the weekend. The clarity does 32 miles a day with free charging at work so it rarely gets plugged in during the week.
  13. M. Shah
    M. Shah Member
