LEAF Spy Pro on 2019 Leaf
Discussion in 'LEAF' started by David Douglas, Jul 16, 2019.
  1. David Douglas
    David Douglas New Member
    Anyone running Spy Pro on a 2019 Leaf?
    if so any recommends on an OBDII that works well
    Thanks
  2. Kenneth Bokor
    Kenneth Bokor Active Member
    KarriO likes this.
  3. There is chatter out there that the stats off of Leaf Spy are not as accurate on the 2018 and 2019 model. It seems pretty accurate to me in my use with my Plus. Any substantiation? How has degradation been on your 18 Leaf so far?
  4. Kenneth Bokor
    I would agree with that somewhat. My 2018 has about 35,000 kms and I've only Rapid Charged about a dozen times so far. Vast majority is Level 2 at home. SOH shows just under 93% and it showed about 98.9% when I got it new. So I don't think it is bang on and I mainly use it for monitoring battery temps.
  5. Ed Dixon
    Ed Dixon New Member
    While Leaf Spy Pro works with the 2019 Leaf, it gives inaccurate battery info and stats. It hasn't been updated in 2 years and is not setup for the 2019 model.
    The basic operation is good and things like codes seem to work as well. But battery size selection does not include the correct options for the 2019 Leaf Plus (which has a 62KW battery).
  6. It has been updated for the 62 pack, and has worked just fine for myself and our 2 Leaf Pluses.
    The BMS hides a few percent of SoH in the first 18 months we think to protect the battery.
  7. Ed Dixon
    Ed Dixon New Member
    Not here it hasn't. iOS version shows 1.7.38, from 2 years ago. Largest battery is shown as 60. Other features also don't support the 2019 model in the iOS version.
    Ed
  8. Facinating. I have been using the Android version.
  9. New2LEAF
    New2LEAF New Member
    Hello?
  10. New2LEAF
    New2LEAF New Member
    Just trying to tighten out how to use this site.
    I have recently purchased a 2018 Nissan Leaf and wondered if anyone had recommendations for best options for winter tires and rims??
    KENNY likes this.
  11. Rich Wener
    Rich Wener New Member
    I have 2016 Leaf, bought used, that is a great car. I just purchased an OBD (KONNWEI New KW902 Mini ELM327 Bluetooth Wireless OBD-II OBD2), to use with Leaf Spy (lite for the moment) but haven't been able to get it to work. The light is on so I assume it gets power. I plugged it in, then turned on Leaf, then booted Spy Lite - but nothing on the screen. The device shows up on android bt options, but when leaf spy tries to connect and I get the message '(bTs) read failed, socket may be closed or time out, read ret - 1.' Any help appreciated.
    Rich
  12. KarriO
    KarriO New Member
