DCFC or L2?Do you have issues charging ? My Kona refused to start charging several times already. I locked it unlocked it, moved to a different parking stall with similar charger and no luck. The chargers were working.
This is very annoying because I don't have a charger at home.
Regular L2 chargers in public parking.DCFC or L2?
Check no charging timer onRegular L2 chargers in public parking.
It was definitely off. That's the first thing I checked. In fact, during one of these days it would charge at one station but not the other in a couple of hours time.Check no charging timer on
That's...not great. Please let us know if you've had better luck at other chargers.It was definitely off. That's the first thing I checked. In fact, during one of these days it would charge at one station but not the other in a couple of hours time.
I changed the LCD setting in Doors to "auto unlock off" to save wear/tear on the door actuators when shutting off/parking the car and couldn't open the charge port after leaving the vehicle and closing the driver doorDo you have issues charging ? My Kona refused to start charging several times already. I locked it unlocked it, moved to a different parking stall with similar charger and no luck. The chargers were working.
Yes I have tried that w/KonaTom at an ABB DCFC 50 kW and no go ( machine said "communication error, shut of vehicle")which it was shut off so definitely a handshake error with ABB. Not the first Hyundai with that error, hope ABB/BC Hydro fixes itDid you try the button next to the battery indicator, in the charging port? I haven't had to use it myself but I read the manual b/c I'm a geek and apparently it is supposed to tell the car to charge immediately including if necessary overriding any timers (and yes I know you said you didn't have any set and I believe you). I think you have to press and hold it like for 3-5 seconds, and supposedly the car should start charging immediately. It's a button right next to the 3 green light bars inside the charger port area. Anyway... I would say try that if you have the same problem again, and let us know if it works.
Oh and, I guess it's also possible there was just a problem with the charger, like some malfunction on their end that had nothing to do with your car.
Just got a report from KonaTom and one DCFC that does work:That sucks, I can't remember if you already said so but hopefully you can charge at other DC fast stations. Now I'm wondering if mine will work, I've only had the car 2 weeks and I haven't needed to charge except at home. I have DC fast about 10 minutes away, I think it's EvGO network, I will have to let the battery run down a bit sometime and give it a test to make sure it works.
