I want to purchase and install a "plug-in" EVSE using a 14-50 receptacle, but IIRC correctly, electrical codes here in the U.S. now require all garage receptacles to be GFCI.
Chargepoint's website says "if local codes require a GFCI breaker for plug-in installation, ChargePoint recommends a hardwire installation. We do not recommend using a GFCI breaker as the Home Flex already has integrated charging circuit interrupting device (CCID) protection. Using a GFCI breaker in the panel, especially with a plug-in installation, can cause nuisance breaker tripping in certain circumstances and interrupt charging."
Would I be correct in assuming licensed electricians are not going to be willing to install a non GFCI 14-50 receptacle in my garage?
Anyone here have experience with this issue? Thanks in advance for your help.
