my mini range is at 88miles max at 100% charged.
its only 2 weeks old car and have 500 miles on it.
Don’t worry your car improve as you driving longer distances as my GOM 100% charged showing 88 miles or 114 miles usually for first 15-20 miles nothing changed I’m driving like not using any electricity from battery you must drive very short distances or you worry a GOM shows 88 miles that GOM is stupid setting and I drive only on sport setting bc I like speedy car and better response I use also one pedal driving if you new to EV as my pattern shows to me my driving 80 miles both ways I’m coming home with 50 miles at least on stupid GOM meter and I’m driver as on my route on Belt Parkway NY Teslas owners doing 55 miles/hour try to milk a milage of their cars as I know my distance to get home without charging I beat a crab of electric go cart which is a blast to drive challenging those BIG SUVs they think they faster than small Mini Cooper SE . Six years experience with speedy BMW I 3 .my mini range is at 88miles max at 100% charged.
I believe the GOM goes by last drive only, plus I'm convinced it factors in current weather somewhat. If one only drives very short trips the GOM tends to show a much lower range.Since you also only have 500 miles, it doesn't have much driving history to go by, either.
Don’t look at GOM just drive a car that car you drive slow or fast give you 100 miles minimum on green sport setting high speed or crawling in traffic why you new owners read about on internet to educate yourself that car is doing 130 miles on average those GOM is crub as I’m only 4000 miles I never have a problem to drive 120-130 miles and only depends on my garage L2 charging.I believe the GOM goes by last drive only, plus I'm convinced it factors in current weather somewhat. If one only drives very short trips the GOM tends to show a much lower range.
GOM meter got nothing to do with your range as I pic up a car in January in cold condition in CT 20F and 65 miles drive to My house in Staten Island I arrive with 50 miles on my crappy GOM meterThe "Range" is called the "Guess O Meter" by many. It doesn't really tell the story very well and is generally VERY conservative. Since you also only have 500 miles, it doesn't have much driving history to go by, either.
Over these 500 miles, what is your actual average efficiency in miles per kwh? My car has a average right at 4.0 mi/kwh since I reset it in the spring when I put the summer tires back on. Before that, it was doing 3.6 mi/kwh over the winter with the all season tires. Just last night I did an 84 mile round trip and was seeing over 5 for the drive up in Green+ on a nice mild evening. Overall I went from 100% to 37% for those miles (about 4.7 mi/kwh).
Rob
Just putting it out there, but I can’t be the only one here who regularly resets their trip meter inadvertently. I find it easier to use the edge button to bring it up (rather than scrolling through the displays with the stalk button), but seem to always hit it again for whatever reason. Why couldn’t it use a long press, like almost every other car on the planet??Next time you have your battery at 100%, reset your trip meter to zero miles.
The GOM does not learn from your driving habits...
The GOM is useless
^ Also my observation and experience ^
And yet nobody's been able to perfect the progress bar on computers, which is kind of the same thing. And computers have been showing those for over thirty years.I happen to think that if we can send a Tesla into outer space, we should be able to make a more accurate algorithm for estimating EV range.
It used to be the cool kids who called that “fuzzy logic,” — aka “many-valued logic” — but now it’s cooler to call it “AI.” Except that it is not really AI at all, just simple non-Boolean logic.I happen to think that if we can send a Tesla into outer space, we should be able to make a more accurate algorithm for estimating EV range. It should have variables including weather, recent driving, repetitive trips, driving style, and integration with the navigation, all weighted accordingly.
Look for 2022 Mini Cooper SE mirror cup that AI is stupid nothing shows on internet as old dud I’m not so advanced like you younger folksIt used to be the cool kids who called that “fuzzy logic,” — aka “many-valued logic” — but now it’s cooler to call it “AI.” Except that it is not really AI at all, just simple non-Boolean logic.
I always reset to 0 my driving distance once I charge to 100% and look what is milage left never run out of juice ever on I 3 or SE and never use a charging on my trips just my L2 in garage bc I don’t travel for work and every trip I know what milage I have to cover with my 100-140 miles range .Doing 5/miles on highway makes now difference if I do 65 I always get 100-140 miles.Just putting it out there, but I can’t be the only one here who regularly resets their trip meter inadvertently. I find it easier to use the edge button to bring it up (rather than scrolling through the displays with the stalk button), but seem to always hit it again for whatever reason. Why couldn’t it use a long press, like almost every other car on the planet??
I find out bc I’m spirited driver my SPORT mode is a best setting as driving only on GREEN for few months I did not notice a any difference of milage/range but a car is alive in SPORT modeI always reset to 0 my driving distance once I charge to 100% and look what is milage left never run out of juice ever on I 3 or SE and never use a charging on my trips just my L2 in garage bc I don’t travel for work and every trip I know what milage I have to cover with my 100-140 miles range .Doing 5/miles on highway makes now difference if I do 65 I always get 100-140 miles.
I got the OBD extension cable with the built-in switch precisely for ABRP so I can leave it plugged in between longer drives. All my future coding, however, will be done via ENET. And I told my wife when I ordered the car that I wouldn’t be messing around and modifying and “improving” this one, yeah right!A Better Route Planner is the closest we'll get for this generation of SE (especially if you pair it with a Bluetooth OBDII adapter.
