When to use Winter Mode
justfortheride
Hey everyone,
Just curious about when I should be turning on winter mode? I peeked briefly through the manual and didn't see any guidance about this.
Your insight is appreciated!
Hey everyone,
(1) Charging performance - good demonstration of assistance in charge rate at low temperatures here:
https://insideevsforum.com/community/index.php?threads/2020-kona.6763/#post-76009
(2) Avoiding restricted power at really cold temps (<-10 degrees C) and low SOC (<20%) determined by the EPCU in the car (this video start at 1:27):
In a nutshell - It won't affect available power until -10C and will only affect charging at below 15C, so any time after the temp drops below 16C and just leave it on until the ambient is above that threshold .
To add to that, there doesn't seem to be any reason to switch it off unless you are in a situation where you need the most kilometers out of the last few percent of battery energy and it's under -10°C. It's fully automatic.
