As noted, nobody has run a curve yet so there's no hard data other than that it's probably somewhere between 20mph and 40mph; exactly where will depend on the car's parasitic load, optimization of the electric motor, aerodynamics, and characteristics of the tires. Heck, it probably changes depending on weather--I know my last car got noticeably less electric range when it was raining, so the peak of the curve will probably shift too.
That said, climate control will definitely be a factor; the more energy climate control is using, the higher the most efficient speed will be.
Logic: If the car had perfectly efficient electronics, it would use 0W of energy other than the power going to the wheels, and the most efficient speed is probably near zero because that's when air resistance is the lowest. More realistically, the parasitics use 500W, then at very slow speeds, because it takes longer to get where you're going, you are wasting more power during that time. So a somewhat faster speed will be most efficient.
If it's really cold out and you're dumping 5000W into the climate control, then driving faster will provide a significant benefit, because you will be wasting less of that energy the less time it takes you to cover the distance. I ran across some numbers for a different EV that showed with the climate control off the most efficient speed was around 20mph, but with the heater cranked up it was around 40mph.
