If you charge over regular wall outlet, consider having electrician check it. Should be dedicated, minimum 15 amp outlet with wires attached by screws (on inside of wall side of outlet) and not "stab" connectors (where wire inserts into hole and held by friction).
If this isn't in the manual it should be.Viking79, I'm curious as to the part of your comment I highlighted. Where did you get that information? Is that part of the building code?
prestoOne,If this isn't in the manual it should be.
Those back stab connections are not as mechanically sound or make as good as a contact as the screws.
100% go with the screw, in fact all the outlets on that line (if not dedicated should be the same).
Fine. What is not going to happen here is me writing a paper for you.prestoOne,
Same question to you: Why do you say that? Is there some reference you can cite that sates this?
You can ignore the advice and increase your risk of a host spot, broken outlets and a fire.
or
You can blindly follow the advice.
or
You can do a simple search of google and make your own mind up.
If you find people saying backstab is better be sure to let us know.
Just naturally abrasive. You asked for too much work and could have googled the forums, that is all. Of course the NEC isn't going to speak against their own proposal. Check out what the pros do.prestoOne,
Sorry if I hit a sore spot. I was only asking a question. Since the NEC (I'm in the US) doesn't state a preference for screw terminal attachment vs. "backstabbing", I was wondering if you knew something that I didn't.
And I have done some research and found an equal number of people claiming a preference for screw terminal as for backstabbing. Mostly because there is a type of receptacle that uses what some term "backwiring". A backwire receptacle uses a screw to tighten a plate down on a wire, not a spring clip. Not being an electrician myself, and having only seen "backwire" type receptacles, I wasn't aware of the backstabbing type.
