As I read all three pages of this conversation, I was wondering how the Kona's regen handles loss of traction. In my old i3, if the drive wheels (rear on the i3) lost traction even for a millisecond (like due to loose sand on the road, or some rough road surfaces), the regen would cut out 100%. Since in the i3, you can't shut off or vary the level the regen yourself, it had this safety feature to prevent wheel lockups. So i3 drivers are trained to always be ready to pounce on that friction brake if this type of situation occurs. I did need to slow down more quickly than I thought recently when my kona hit some rough road at an intersection where a car pulled out too early in front of me. I let off the accelerator expecting the initial slow down from the Kona's regen (set to 3) but it just wan't there, so I had to quickly apply the friction brakes. But I do believe I may had lost traction on that initial full off the pedal Level3 regen.
Does anyone know if this feature of the regen cut off is something also found in the Kona electric? I'm sure I will find out when I can play in the snow once Winter comes.
