Why is the inverter for a V2G so expensive £8000 to £9500 for a 10KW unit per Drive Electric in UK.
https://www.drive-electric.co.uk/dr...le-grid-charging-service-uk-homes-workplaces/
Is there not an inverter in an EV and why is this not available to connect the stored battery to the grid ?
Are there not 2 pin terminals available on the socket connection on an EV (CCS or Chadamo) available to connect the battery to an external inverter (which may be connected to a solar panel at the same voltage) ?
