Used: Battery Degradation & Range
  • Thread starter Thread starter voltron
  • Replies Replies 13
voltron
I am considering buying a used Mini Cooper SE, but am having second thoughts due to the already short range being materially reduced by battery degradation. I looked at a 2022 with 40K miles on it, and at an ambient temp of 55° F, charged at 50% (exactly), it showed a range of 45 miles. That means a 90 mile range fully charged, which would indicate ~20% battery degradation in slightly over 4 years in service.
Of course, it's not as simple as looking at the charge percentage and range, but it should be in the right ballpark, so the magnitude of this discrepancy raises serious questions.
My question: for those of you with Mini SEs, what range would you expect to see on your car in ambient temperatures of 55 - 60° F? How much battery degradation have you seen in your cars?
Ignore the estimated range. It is meaningless in this context (and barely meaningful ever).
I spent a fair bit of time on forums such as this one. I have yet to see anyone report any detectable decrease in range, even after more than 100,000 miles and frequent DCFCing.
Anyway, to directly answer your questions:
1) about 150 (actual, not what the GOM reads - I basically never look at it); and
2) None. In fact, I am getting slightly better range now than the first two years I owned my SE, presumably because I changed the route I take to work, replacing 6 miles of interstate with 5 miles of 30-50 mph state highway.
I purchased an OBD2 bluetooth dongle and the "EVScanner" iPhone app to run battery diagnostices before I purchased a 2022 SE earlier this year. I was concerned about battery health and the app helped me to feel more confident making the purchase.
The onboard range estimate ("Guess-o-meter") seems to be very conservative. Our weather has started to turn colder with lows in the 30's. On a recent charge the car reported that it would be able to go 87 mles on a full charge. I ended up going 70 miles on 69% of that charge with all-weather tires and running the heater. I probably would have gotten 100 miles out of the full charge despite the 87 mile estimate. Warmer weather and summer tires would improve that range.
My understanding is that the SE battery is over-provisioned at the factory. (There is more capacity provided than reported.) That conservative design should help with the long-term health of the battery and minimize degredation.
Welcome to the forum. Enjoy your research and hopefully your new SE.
Echoing what the above comments that the SE's GOM is notoriously pessimistic and cannot be used to gauge actual battery health. Browse through the Anyone keeping track of the battery's soh thread for an extensive discussion with several real-world reports.
At 4 years of ownership and over 21k miles, my 2021 SE reported a 4% battery degradation via Bluetooth OBDII dongle with no detectable reduction in range. If I recall correctly, it hit 4% degradation by year 3 and basically stayed there. Mostly short commutes in town with a few long road trips.
  • Like
Reactions: Zim
My 2023 since new has always shown a lower number for range than battery percentage. After a full charge it will show over 100 miles and immediately drops under 100 miles after a few miles of driving. I never pay attention to the GOM now and after 26k miles will still give me 130+ miles of range per charge driving around SoCal.
The GOM on the SE is basically worthless. Best advice is to live with the car enough to know what battery percentage will get you where, on a daily basis. We have a 22 SE with approximately 60,000 miles, the OBD dongle linked to ABRP (a better route planner) is reporting a battery degradation of 4% -6% (it jumps between those two). That's the reported number, from our real world use case we haven't noticed any loss in range. We will plan on 100 miles per charge (worst case) in the mild Pacific Northwest winter, including temperatures around 35F, heat on and standing water on roads. Summer returns approximately 150 miles.
Assuming you don't need to drive 70+ MPH everywhere, all the time....1% should safely return 1 mile while building trust in what the vehicle can actually deliver within your daily driving habits.
There is a way to display battery percentage on the instrument cluster.
The GOM estimates range primarily based on the previous trip only, so it will be wildly different after each drive. Think of it as worst-case range instead of what you're likely to get. I've found the GOM estimate to be very conservative until SoC is down to around 25%, at that point things like regenerative braking won't make as much difference since there's not a lot of range left.
I have driven over 119,000 miles on my SE and I have not noticed any range drop. I still can get well over 130 miles per charge in summer weather.
I recently sold my SE after 35,000 miles. I was still getting over the EPA range in the summer. I never noticed any degradation whatsoever.
The guessometer on the dash never ever was close to accurate since day one when the car had 10 miles on it. Like others said, in the Mini it’s rearward looking. If the last person drove it like a go cart it’s going to read low. Other cars calculate the range based on the upcoming route, elevation, weather, speed, etc and can be quite accurate. The Mini is older tech and not like that at all. I could drive mine down from the mountains and probably have it read 150 miles the next day. I just never ever looked at it in 4 years. It was that bad.
I think I'm probably one of the worst cases for the car. Low-mid 80s on the freeway is keeping up here. It gets real cold in the winter and I refuse to suffer so I blast the heat. I also run high rolling resistance sticky tires in the summer and high rolling resistance knobby snows in the winter.
Car gets about 92 miles of range in the summer and 80ish in the winter, total miles have not changed noticably since purchase. Single digit temps will drop my range under 80.
Yeah the GOM may be useful for trending when your driving routine is consistent. I use the % remain as an estimate of range for the current conditions. The 1% per mile is a conservative and easily calculated estimate otherwise.
Based on my experience and driving style a 80 mile 45 mph round trip commute on a summer 80 degree F day routinely uses 50% more or less (1.6 mile per %), in the winter 20 degree F weather uses 70% more or less (1.1 mile per %)
Highway driving at 65+ mph average I will use about 80% in 90 miles more or less summer time 60 degree F days (1.1 mile per %).
I use heat and AC, may moderate speed when I think I may be pushing the range limit and don't want to stop for a charge.
I have not noticed any range degradation over the 4 years and 25,000 miles we've driven. Before and after a long drives we charge to 100% and may leave the car parked for a couple days.
How close the indicated % reflects the actual battery % I dunno off hand, but don't really care.
I have 51,000 on my SE. Battery SOH is 93% Get a Bluetooth obdii thing and check SOH with one of many apps. Ignore the guessometer, it is awful.
My GOM is surprisingly accurate, but very imprecise. It is almost perfectly 40% low. If you add 40% at any point, it is pretty much spot on. I haven't noticed any range drop in over. 5 years. I am sure it is there, just not noticable.
Isn't that precise, but inaccurate? ;)
