Updated NAV / MAPS eta: Mid-November
  • Thread starter Thread starter Tim94549
  • Replies Replies 15
Chatted with Map-n-Soft team .. Was told an Update to NAV/MAPS is due out mid-November.
Unfortunately, what this really means is: we have worked solidly to introduce new bugs and assorted problems and plan to issue these in due course. Please note that we have not made any attempt to fix any bugs that have been reported this year. The new ones will be exactly that.
Can anyone spot my deliberate mistake? OK, I confess: there isn't one. Ask Hyundai whether they have ever fixed a reported bug .....? FWIW I sent them a long list of the bugs that I discovered last February. Not one was ever fixed.
Lawrence H
As is often the case, I just cannot find any link. The 'update page on Hyundai's site only lists the May update - which has been there a very long time.
Lawrence
FWIW I just downloaded/installed the updater - and was told that it is exactly the same edition as the last one.
Lawrence
I installed the update. Not much new, just a few new Sounds of Nature, and they brought the EV screen from Ioniq 5 down to the Kona. The only new piece of information it shows is the difference in range with climate on or off. The other changes aren't really worth talking about.
I installed this the other day.. unfortunately it made the voice command to find an address not work. It thinks for a while and then I get a message that there was no server response
Installed latest update/ Took about 1 hour 15 mins to install. Initial thing I noticed is that the SIRIUSXM panel on the right side now has a 'washed out' appearance. Like the station ICON DISPLAY is bleeding into the panel - almost looking like the screen has burned out image or something. (hard to explain, but very obvious). When I scroll UP/DOWN to the other screens, like Charging, Compass, Time, etc, the screen looks just fine. It's just the stations on SIRIUS that look bad. I'll open a ticket with the MAP-n-Soft team to report this.
Pretty sure that's intentional. The background of that pane is blown-up and heavily-blurred copy of the album art.
This is new in this release. Frankly, it looks bad, imho. Like they're "mirroring" the station id (e.g., CNN) that is causing this bleed thru appearance. What is the point?
I updated and now I'm getting the same error message.
Finally tested this yesterday. Working fine for me. Are you still having that issue or did it go away?
