When do you hear the noise? When you're cornering right? When you're cornering left? When you're going over a speed-bump? When you're accelerating or decelerating? When you're decelerating using regen or using the brakes? When you're going fast or slow? Is the noise constant or intermittent? Can you make the noise happen upon command? If you can make it happen on command, you can demonstrate it to your dealer's service personnel. If it's intermittent, it will never happen when you want it to.I don't drive our Ioniq as much as my wife, but yesterday while driving noticed the undercarriage was making noise that wasn't road noise. Kind of a creaking or shifting noise. I don't recall hearing that before. It seemed to be coming from the rear. Anyone have similar issues?
If you can make it happen when the service advisor is riding with you, maybe they will figure out where to look.I should have been more specific. It doesn't seem to be drivetrain related, more like something is loose. My wife thinks it is a creaking sound. Not using the brakes nor accelerating.
Rear hatch, perhaps?When do you hear the noise? When you're cornering right? When you're cornering left? When you're going over a speed-bump? When you're accelerating or decelerating? When you're decelerating using regen or using the brakes? When you're going fast or slow? Is the noise constant or intermittent? Can you make the noise happen upon command? If you can make it happen on command, you can demonstrate it to your dealer's service personnel. If it's intermittent, it will never happen when you want it to.
