KiwiME
Yesterday I took a 290 km day trip, ... partly to try out my new gear reducer oil and double overhead magnetic drain plugs. As usual I made the effort to log OBD data. Everything looks normal except that I noticed the trip energy rate display read 1.02 kWh/100 km less than what I actually measured using the BMS energy odometers CED and CEC. Those BMS registers are incremented by integrating the product of current and voltage over time, both exiting and entering the pack. They need to be accurate to determine what SoC to display on the fly.
My trip total net energy usage from the battery was 44.43 kWh.
The Accumulated info display read 14.3 kWh/100 km, or 14.3 x 290/100 = 41.47 kWh total.
Missing from the displayed info is 44.43 - 41.47 = 2.96 kWh. The drive time was indicated as 4:13 hr:min or 4.22 hours. So, on average a load of 2960 Wh / 4.22 h = 701 watts was not accounted for while the car was in Run mode.
If I consider worst-case error margins the display could mean 14.39 x 290/100 = 41.73 and my logs 44.33, a difference of 2.6 kWh or 616 watts. So, that's not the problem.
The power use display on the media centre (which is mislabeled as Energy Use) told me that the Electronics (the 12V system) was using about 200 watts and the Climate (AC) was using using roughly 250 watts, numbers we probably all see. (As an aside, I'd be impressed if the car can run all it's essential systems on a mere 200 watts.) So, it could be that the Accumulated info ignores those overheads, and perhaps additionally fixed power draws may be underreported.
I'm wondering if the trip display does not account for anything other than the inverter and the motor? Or, is it simply not very accurate?
This is not the first time I've noticed this but it is the first time I've paid attention to it.
