Transmission Fluid Change
  • Thread starter Thread starter Robbiemo
  • Replies Replies 11
  • Views Views 7K
Robbiemo
Anyone have any experience with changing the transmission fluid themselves yet, I just crossed over 45k miles and I'd like to change it soon.
I'm not sure where the drain/fill bolts are (haven't looked yet) or what type of fluid and how much it will take.
The manual specifies Honda ATF DW-1 and indicates it requires a dealer to both check and replace. I am unclear what the recommended change interval- but for some car models, it is considered lifetime. I believe the maintenance minder will generate the needed code when maintenance is necessary. In any case, the dealer may be you best source of information.
Sent from my SM-G975U using Tapatalk
I think it's for the clutch. The clutch is a "wet" clutch, so it does need some fluid to work, and sure it's not engine oil.
I'm referring to this page: https://global.honda/innovation/technology/automobile/hybrid/i-MMD-picturebook.html
These gear and clutch should be submerged in oil.
This thread was largely picked up under the Clarity "subfolder." Since the engine will transmit power directly to the wheels using a 3.42 final gear ratio, I assume this coupling mechanism is referred to as the eCVT. And it would make sense that this would use ATF or similar type fluid.
The Owner's Manual states: "Have an authorized Honda Clarity Plug-In Hybrid dealer check the fluid level and replace if necessary. Do not attempt to check or change the transmission fluid yourself."
The Maintenance Minder System document states: "*3: Driving in mountainous areas at very low vehicle speeds results in higher transmission temperatures.
This requires transmission Fluid changes more frequently than recommended by the Maintenance Minder. If you regularly drive your vehicle under these conditions, have the transmission Fluid changed every 96,000 km (60,000 miles) or 3 years."
Thus, you don't need to have the transmission fluid changed and you definitely should not try and do it yourself.
Yes, I meant Clarity. Clarity uses the same i-mmd system as insight and accord hybrid do, only difference is larger battery and smaller engine.
The eCVT name is totally misleading. It is, in fact, just generator wired to motor, with battery as buffer in between. The clutch is the mechanical link for certain high speed conditions, where the fixed ratio gear can provide better efficiency than converting mechanic power to electricity and back.
