quietlyspinach
Does the Cooper SE have an actual TPMS sensor installed in each tire? If so, why does it need to be calibrated for several minutes before it's capable of giving an actual reading?
I used to own a 2006 MINI Cooper and it had a TPMS system that used the rotation of the wheels to determine if one was lower than the rest; it could not actually tell you the real tire pressure with no movement. And even then it never read actual numbers; it just knew if it was "low" or not.
So I'm puzzled by 2022 Cooper - it seems like it must have a TPMS in order show real numerical readings, but I don't understand why I can't get those readings when I start up the car in the morning without having to press a button and wait for a few minutes after driving it around.
