stacey burke
My question is not how much a new one would cost, the car would be 8 to 10 years old. My question is can the car run as a Hybrid after the battery is shot?
Unlike conventional hybrids, the big battery of the Clarity will last a long, long time if you just need it to run fine as a hybrid. You can even lose 80% capacity. After all, there's only two bars when the car switches over to hybrid mode. If you take care of the battery, there's no reason you shouldn't have at least 20% after 20 years.My question is not how much a new one would cost, the car would be 8 to 10 years old. My question is can the car run as a Hybrid after the battery is shot?
In 8 to 10 years, the car's battery will lose capacity, but the capacity will not be zero! So yes the car should run as a hybrid just fine after 8 to 10 years.
Note, there is a post that shows how much capacity loss Honda allows before Honda will replace the battery under warranty. That should give you an idea as to what to expect the maximum capacity loss to be at 8 to 10 years, depending on whether or not you live in a CARB state. The battery warranty is 10 years in a CARB state.
Your wish is my command, Marshall. The Service Bulletin for the Pre Delivery Inspection is # 17-093. On the last page, p13, it appears to show in the screen shot that the nominal Battery Capacity Signal is 55 Ah. It states that warranty replacement occurs when it goes below 36.6 Ah which is about 66% or 1/3 loss of 55 Ah.KentuckyKen can you provide that information from the tech bulletin on the capacity loss.
Attached is the SB in PDF.
