The Audi e-tron Sportback officially launches with two battery sizes
Audi has officially launched the e-tron Sportback, the more coupe-like version of its e-tron SUV.
It comes in two versions:
  • Audi e-tron Sportback 55 quattro with 95 kWh battery and 446 km (277.1 miles) of WLTP range
  • Audi e-tron Sportback 50 quattro with 71 kWh battery and 347 km (215.6 miles) WLTP
Besides more range, the 55 quattro also gives you slightly better acceleration - 0-100 kph (0-to-62 mph) in 6.6 seconds (5.7 seconds in boost mode) compared with 6.8 seconds (no boost mode).
It also gives you a higher top speed 200 kph (124.3 mph) versus 190 kph (118.1 mph).
Perhaps most importantly, the 55 quatro has a higher peak DC fast charge rate: 150 kW vs 120 kW.
More specs below.
Audi e-tron Sportback 55 quattro specs:
  • range of 446 km (277.1 miles) WLTP
  • energy consumption of 21.9-26.0 kWh/100 km (62 mi) WLTP
  • 95 kWh battery pack (86.5 kWh net usable); liquid-cooled, nominal voltage of 396 V
  • 0-100 km/h (62 mph) in 6.6 seconds (5.7 seconds in boost mode)
  • top speed of 200 km/h (124.3 mph)
  • dual motor all-wheel drive (one asynchronous electric motor per axle)
  • peak system output of 265 kW and 561 Nm (300 kW and 664 Nm in boost mode)
  • weight of 2,480 kg (3,150 kg gross weight limit)
  • AC charging via three-phase 11 kW on-board charger (22 kW option)
  • DC charging 0-80% in about half-hour, at up to 150 kW, using CCS Combo standard
Audi e-tron Sportback 50 quattro specs:
  • range of 347 km (215.6 miles) WLTP
  • energy consumption of 21.6-26.3 kWh/100 km (62 mi) WLTP
  • 71 kWh battery pack (64.7 kWh net usable); liquid-cooled
  • 0-100 km/h (62 mph) in 6.8 seconds
  • top speed of 190 km/h (118.1 mph)
  • peak system output of 230 kW and 540 Nm
  • weight of 2,370 kg (3,040 kg gross weight limit)
  • DC charging 0-80% in about half-hour, at up to 120 kW, using CCS Combo standard
Here's a walkaround video:
