I was happy to discover the EPA includes entries for EVs in the "Test Car Database" including the roll-down coefficients. This means we can plot the rolling drag power metrics as a function of mph. Using 500 W as the overhead electric load, here are the plots:
Each Y-axis value is equivalent of 5 hp.
These are parametric, loss-less, drag power curves at the wheel-to-road interface. I need the kW consumption at 30 mph and 60-75 mph for each model Tesla to correct the fixed overhead and efficiency loss of these curves. Normally we use benchmarks at two, different speeds to adjust for losses:
- tire flex losses
- there can be shock absorber losses on poor roads
- wheel bearing and CVT joint losses
- differential gear losses
- reduction gear losses from motor to differential
- motor losses (better for PM versus cheaper induction)
- inverter losses (better for silicon carbide versus silicon)
- typical metrics are at the input to the inverter electronics
