The Treasury Department definition that applies is in § 523.5 Non-passenger automobile.
To qualify for the $80,000 limit the vehicle must have 4 wheel drive and SUV characteristics.
Section (b)(1)(i) Has 4-wheel drive; and
Section (b)(2) Has at least four of the following characteristics calculated when the automobile is at curb weight, on a level surface, with the front wheels parallel to the automobile's longitudinal centerline, and the tires inflated to the manufacturer's recommended pressure -
(i) Approach angle of not less than 28 degrees.
(ii) Breakover angle of not less than 14 degrees.
(iii) Departure angle of not less than 20 degrees.
(iv) Running clearance of not less than 20 centimeters.
(v) Front and rear axle clearances of not less than 18 centimeters each.
The AWD ID.4 does not meet the approach angle requirement, but it does meet the other four. (breakover angle, departure angle, running clearance, and axle clearance). Running clearance is not the same as ground clearance.
