So the Leafs I had both had a rust issue on the front strut locations due to improper drainage from the wipers so I decided to take the plastic cowling off the drivers side of the Kona.
There is a plug that fits over the mounting hole so no problem;
But when I removed the plug there was some surface rust around the securing bolt and inside cap(sorry no pictures)
Some Q tips and rubbing alcohol cured that (I will be putting some grease on it later)
GOOD idea to check it now before issues.
I will also be greasing the 12 V battery terminals as they are dry and prone to moisture and corrosion(see under the hinged covers) also a later Nissan fix.
Just a heads up
Just a heads up
