FloridaSun
I'm getting annoyed with bluelink timing out 90% of the time lately..
I usually use bluelink to stop charging on chargers that do not allow to stop charging at the charger or charger app. What I usually do in the case that bluelink is not responding, I go into the car's settings and change the max charge to a percentage lower than the current charge level and charging will stop.. However, if I forget to set it back to the original value, my car will only charge to that level next time I connect it.. So, I don't like to do that.
I read that people would use the unlock button 3 times and then remove the plug. However, on my car, the charge rate does NOT drop to 0.5 kw as others indicated. It stays at the same rate.. It only drops the current when doing that on DC fast but not on a Level 2 charger... so I don't want to use that method as I don't want to do a hot disconnect.. Any input would be appreciated..
