MrFixit
Don't like your EV range? -- Slow Down !
Please spare me the criticism...
I do know that you really can't do this under most circumstances because you will be run over !
There are a lot of factors that can effect EV range performance, and there are many discussions in this forum related to this. One thing that may be underappreciated is speed. There is a tremendous difference in EV range when mostly driving under city conditions vs. 75 mph on the highway.
Performance on a flat highway is limited by 2 primary factors (rolling resistance of the tires, and Air Drag). There are a couple of fairly simple equations that can be used to estimate the power needed (and hence the EV range) as a function of speed. Some of the parameters I used are estimates, but here is a curve that shows how significantly speed affects EV range:
If you are a glutton for punishment, I have attached a screenshot of the basic spreadsheet that shows all the assumptions / parameters that I used to make this curve. It shows a Reddit link where I found a nice discussion surrounding this topic.
You can hardly see it, but this is a thumbnail link below...
