I wonder what kind of sensors the SoulEVSpy offers that Torque Pro does not show.. I remember seeing tire pressure etc.. Would also be interesting to know how much energy each of the accessories pull. Torque Pro only shows me the total energy draw but does not break it down.. I guess I would need more PIDs for that.. I wonder if anyone has PIDs for this additional information.I use SoulEVSpy (paid version) myself - works well with Kona, and it works out of the box without needing a lot of configuration.
There is often more than one component associate with each fuse.. I wonder how the battery usage display of the Kona's infotainment system determines how much current is used for climiate, battery conditioning and accessories?I'm only guessing but I doubt such detailed information is measured. There is a documented current shunt in the battery pack and no-doubt the LDC provides output data along with the 'intelligent' sensor on the 12V battery negative post. I've not seen any others in the docs.
There are some research spreadsheets on Github that uncover some of the PIDs used on the Soul EV, drawn on for the Kona/eNiro. Much of it seems to be revealed by guesswork and experimentation. If you wanted more detail on power usage you could make up a current measuring device by swapping out the relevant fuse with a custom loom including a fuse and a shunt.
