SE will no longer precondition at certain times of the day.
  • Thread starter Thread starter pictsidhe
  • Replies Replies 3
  • Views Views 372
pictsidhe
I moved to second shift a few months back. I finish midnight-ish. My car just will not precondition at 12:15am. It mostly still works daytime, but not always. It's also had spells of the heating being **** and blowing tepid for to 20 minutes. I've tried deleting all the schedules, turned on and off scheduled charging. The car has also been wiping and randomising the schedule up to three times a week, too.
My warranty ran out a few weeks ago, and I'm not feeling a desire to take it back to Mini for an issue raised and not fixed inside the warranty period. Now that the warranty has expired, I'm sure that they will merrily use the parts cannon, at my expense. Anyone had this issue and know possible causes or even the solution? I'm not happy about having to wear winter clothes in my daily driver again. Having a preconditioning car was truly awesome.
I was experiencing this issue off and on as well. When I would check the "Charge & Climate timer" settings in the app after a failed precondition, sure enough "Climatization for departure" was toggled off. I'd turn it back on and it would eventually get switched off again.
Did you enroll in the ChargeForward program that showed up in the app a few months ago? I suspect that was the culprit for me. A few weeks ago I gave up on it and switched back to "Charge in time slot" and I haven't had a preconditioning issue since.
I tried the charge forward thing for about a week. It messed everything up. The failure to precondition issue predates me trying it. I have not had my car turn off preconditioning. I try to remember to send a precondition signal manually. Signal is weak here, so that doesn't always work. The car used to precondition at work and seems to still work if I am working an off shift. Doesn't precondition at home around midnight, either, but works great in the morning or afternoon.
Interesting; I guess our issues are different. Sorry to hear yours isn't such an easy fix :(
