Clarity_Newbie
Data collected Feb 1 - Feb 28th
17 drive days, 751 miles, ~26 hours of driving. 64 log files generated 258,424 data points. GVW 4260. Temps 25F to 58F...several days of rain, couple days of wind.
For perspective...I live in the mountains and run the valley floors which are flat to rolling. Otherwise varying degrees of steepness prevails. For example...I lose ~2 miles EV like clockwork when I drive the last 1/2 mile to the house at ~25 mph.
I operated the Clarity as I would normally do...no special roads or testing conditions. Unlike the first RPM data test which was conducted solely in HV mode, this go-a-round the Clarity was in EV mode 77.8% of the time with the remaining in HV mode. Neither Sport mode nor ECON mode was utilized.
Clarity charged as needed to maintain SoC to ensure adequate EV range available for the next days drive. Typically I charge to 75% - 95% by using 9 hours charge time instead of charge to full.
As I normally do every month, I purposely ran the Clarity in HV mode two days for the entire day. On HV mode days...SoC always 80% or higher.
As a matter of course, when I decide to run the cabin heat...I put Clarity in HV mode.
Both HV mode only days and heat-on events can be spotted on the chart depicting the entire 17 day run. Skinny spikes on chart indicate cabin heat-on events.
Typically I will put heat on, when temps ~ 45F or less...otherwise seat heating does the job...especially when the sun is out.
I used the same breakpoints for February data as January data for ease of comparison. Link to January data for those interested: https://insideevsforum.com/community/index.php?threads/hv-only-gas-mileage.4089/page-3#post-45189
January results in black. February results in red.
Clarity Speed breakdown
Clarity RPM breakdown
Clarity February data with 0 RPM’s removed
Based on 21 drive days (Jan/Feb combined) for data collection (~340,000 combined data points)...the conclusion for the Clarity I drive is I can expect 1000 to 2600 RPM’s while in HV mode with rare spikes above 3000 RPM’s. Weather and/or terrain and/or speed are the obvious culprits for RPM’s above 2600. The chart demonstrates this very nicely.
Hope this helps with those who are trying to gauge RPM’s for their own Clarity. I have empathy for those who express concerns over “angry bees” and/or loss of power accompanied by high revs according to some owners.
Some forum posters say RPM’s haven’t breached 2000...others say 3000 plus is routine. I’d love to see more data so we as a collective whole can perhaps narrow down what is “normal” expectations for the Clarity.
As everyone knows but is still worth repeating...individual driving habits are a huge variable in how this car will operate.
As a side note...HV mode engine clutch engagement remains predictable and consistent. Clutch engagement occurs at speeds of 45 to 70 mph.
pdf attached with some comments and two charts depicting 17 day run...RPM's over MPH.
***These charts/data is not being presented for reverse engineering. The sole purpose is to demonstrate one Clarity’s RPM range with associated speed to folks who believe the Clarity they drive has RPM issues. At least it is a start and some comparisons can be drawn if owners collect OBDll data.
Good luck!
- 1 - 35 mph..........39.4%...........40.3%
- 36 - 60 mph........42.3%...........47.5%
- 61 - 79 mph........18.3%...........12.2%
- 1 - 1000..............40.47%.........78.2%
- 1001 - 2600........56.59%.........20.1%
- 2601 - 3600..........2.39%...........1.6%
- 3601 - and up.......0.55%..........0.08%
- 1 - 1000...................1.9%
- 1001 - 2600............90.7%
- 2601 - 3600..............6.8%
- 3600 - and up...........0.5%
Good luck!
