Sandroad
This thread is for posting information on which aftermarket or Honda brand wheels (of any diameter) that fit the Clarity. If you have installed wheels other than OEM that fit your Clarity, post details of exactly which wheel/part number, photos, and where to buy them. Technical details of the Honda OEM wheels/parts:
Enkei alloy 18X8J: 42800-TRT-N90
Bolt pattern: 5-114.30mm
Inset: 50mm
Hub bore: 64.1mm
Trim assembly (plastic): 44733-TRW-N00
Lug nut: 90304-SA0-981
Valve assembly: 08W16-S47-A0004
TPMS Sensor: None
Honda accessory replacement alloy wheel: 08W18-TRT-100
And, for reference, the OEM tires:
Michelin Energy Saver A/S Honda spec
Load index; 94
Speed rating: V
UTQG: wear, 480; traction, A; temperature: B
Tread depth: 8.5/32nds
Tread width: 7.8”
Max load: 1477 lbs at 44 psi max
Weight: 24 lbs
Diameter: 26.3” (790 revs/mile)
Recommended pressure: 36 psi
Inset: 50mm
Hub bore: 64.1mm
TPMS Sensor: None
Load index; 94
Speed rating: V
Tread width: 7.8”
Weight: 24 lbs
