quietlyspinach
EDIT: I figured it out. Turns out it's basically like those hotel "Do not disturb" tags with a loop on top. If you angle it slightly to the right side and pull straight out, the loop will break cleanly and all of the tag material comes out nicely.
How did you all remove the warning label about advanced airbags that hangs down in front of the glove box opening?
In my past cars I just peeled it away, but this is firm piece of plastic that appears to be attached under the trim piece over the glove box. Is there some trick to this, or I do I have to take a pair of scissors to it? I don't think I can trim that close to the opening and I don't want to leave a tiny white piece of plastic near the top!
