victor_2019
I noticed, at least compared to my kona EV, that the regen capability of the clarity is not that great.
the kona in the highest regen setting can really slow down the car quite fast and in the dashboard display you can see it adding a lot of distance worth of energy back in the battery (I've seen it add several kilometers worth when slowing down from highway speeds).
but the clarity EV range barely moves by a few hundred meters when doing regen and even on the highest setting, the car doesn't slow down that fast. in the kona I can rely on the regen only to slow the car down and stop it without the brake, but when I try the same thing in the clarity it usually ends up with a hard panicked braking halfway through when I realize it won't slow down fast enough on regen only.
also, one thing I've seen and I always found it funny, is that when I select the 4 levels of regen, sometimes the 4th chevron will blink then disappear. then I select level 4 again, and again it blinks and disappears. finally I can select 4 levels.
almost as if the car can't handle too much regen...
then on my last trip it suddenly clicked that this always happens when I select level 4 regen at high speed and that is when the most power can be generated, so it really must mean that the car can't absorb all that energy.
and I realized the difference between the clarity and the kona.
the kona has a 150 kw motor and the battery can handle outputting 150 kw of power to the motor, and also to accept this kind of power back from it (or at least most of it, since it can charge in theory at 100 kw from a fast charger). so it can use a lot of regen.
the clarity power train on the other hand has a 135 kW motor however the motor can't produce that power from battery alone, on;y when the combustion engine is also providing power via the generator, because the battery doesn't have enough capacity.
so that must also mean the battery doesn't have enough regen capacity...
but if the car in EV mode can produce decent acceleration, why can't it produce similar regen deceleration? is the battery power capacity smaller in charging than in discharging modes? (can discharge faster than it charges?)
perhaps someone can clear some of my confusions...
