Rear wheel fender clearance and suspension/brake observations
  • Thread starter Thread starter V8Power
  • Replies Replies 0
  • Views Views 856
V8Power
I swapped tires over to winters today and jacked up the car. In case anyone is wondering, there’s ample clearance to remove the tire when it’s unloaded. While it was exposed I looked around and noticed the suspension and structure is extensively aluminum, looks sophisticated with no signs of rust or corrosion. Also noticed that, the brake disc surface was show little signs of wear after 4700km, a good sign that the regenerative braking is working well by just using the brake pedal. My wife doesn’t use the regen paddles.
