RAV4 EV BMS_f063 Alert, Car won't run or charge. Suggestions?
centolam
Hi,
I changed my 12V battery on a 2012 RAV4 EV and didn't disconnect my main pack when I put it in. I also accidentally left the car on overnight after I changed the battery.
I have an EV system error. The car won't go into gear or charge.
I got a version of the Tesla RAV4 EV Diagnostics software and made a connector, and also got a version of the Toyota Techstream diagnostics software and got a connector going on that too. I tried clearing codes with both softwares. I also checked every fuse in the 2 internal fuse boxes and the 2 on interior boxes on the driver's side. I also reinstalled the main pack cutoff under the passenger seat to be sure that was seated properly.
The only reoccurring code now is a BMS_f063 Recharge Failure Alert on the Tesla software. I posted the Tesla software suggested causes for the fault (appended below).
Interestingly, one of the potential causes is that the pack is being misread. I had an aftermarket Chademo installed that speaks to the BMS directly and has a network link so I can see the output. The direct connect indicates that the BMS thinks the SOC is 97% and also that the Pack Voltage is 0.
The car was only charged to 80% on the last charge and it's been sitting for 2 months so it's SOC is not 97%. I'm wondering if the BMS is perceiving the SOC to be 97%, when it's closer to 0 and if this is at the root of my issue?
I'm in Oklahoma City. I initially had the car towed to Toyota. They had it for a month and were not able to get their diagnostics software working and asked me to take it back.
I'm looking for some suggestions on taking the diagnostics to the next level.
Also, is there a RAV4 EV repair expert out there that consults on repairs?
Active Alerts Potential Causes (Tesla Powertrain Diagnostics Software 1.1.42
HV Open
Welded Pack Contarter
Faulty Pack Contactor Drive Circuit
Disconnected Pack Voltage Sense line
Faulty Precharge relay
Faulty Precharge Resistor
Faulty current Measurement in Pack
Faulty BMS Component
High Voltage Bus Capacitance is incorrect
Faulty Pack contactor
DC Link voltage is too high
Unaccounted for HV load
HV short
thanks,
Mike
