Phil_Meyers
Some sputtering then some error messages come on the screen. Later went to fill it up. Took 7.15 gallons. Back to normal.
Did you do this on purpose as an experiment? How far did you travel after the tank went dry?Some sputtering then some error messages come on the screen. Later went to fill it up. Took 7.15 gallons. Back to normal.
It was on purpose, I drove another ten miles or so. It was rather all anti-climatic but I guess that's good.
The tank is pressurized. But there is also a fuel pump at the tank to get the gas to the eng. PN:17045-TRW-A00
Cost about $350 and a pain to replace since you will need to drop the entire tank to get to the pump.![]()
