I bought a Ryobi model from Home Depot.
I would have gone with a Karcher as that’s what I used to have but my local store didn’t have any at the time.
It was 2.5 years ago so models have probably changed however it was an electric unit and was about 2200 or 2300psi.
Note that the psi rating is a max, and the way it is controlled is they give you a set of nozzles that swap out on the end of the “wand”. The highest one is for cleaning your concrete and I did use that (on the concrete driveway not the car) but it is such a pin like concentrated spray you’d be there all day…
I use the mid grade nozzle and hold it at least 18 inches from the car. (this is the trick to avoid damage, not reducing the rating of the unit) This is the way I have cleaned cars the last 20 years. It gives enough power to dislodge most bugs and dirt while not damaging the car. Do not point it at parking sensors, or directly at the radiator etc.
If you can get one that has the ability to add shampoo to a reservoir in order to coat the car in foam that does save time, but my unit, while it has that, gives no way to switch between foam and clear water so I don’t use it. Instead I use an attachment called Adams Foam Cannon that goes on the end of the “wand” instead of the nozzle. I coat the car with that foam, use a wash mitt to get all the stubborn stuff off, then remove the foam cannon, replace the nozzle and rinse off.
Downsides:
We have hard water here so that can leave water spots so I make sure to dry the car immediately with a towel even moving it into the garage first to do so to get it out of the sun.
This hard water killed the wand within 2 years. Nothing was coming out due to a nozzle blockage, then it burst somewhere inside the wand gun and that was that. However the wand is replaceable so I ordered a new one only for like $30 and was back in business.
The problem may have been the nozzle clogging rather than the wand gun so I also replaced the nozzle. It was like $7.
As a side note, both my cars have full PPF coverage and no the pressure washer does not take it off. Again, I don’t hold the wand near the edges and most of the edges on our cars are wrapped around to the backside of the panels anyway.
