The Clarity has been my daily driver for the past 18 months and it has been great. I hope Honda keeps developing this platform for another generation, and hopefully make it a hatchback with 2.0L engine and 20kWh battery. But for the current Clarity, the only issue that I had with the car during long road trips in the mountains was engine power in higher elevation and for steep grades. I wish the engine had more power. Therefore I was thinking maybe using premium gas can result in some extra power. Now usually Atkinson cycle engines work better with low octane gas (older Prius models for example), but with Clarity having relatively high compression ratio (13.5:1) is it possible that you can get extra power with premium gas? Now being an Atkinson engine the effective compression ratio is probably lower than 13.5:1, but still it could be high enough to benefit from premium gas. What you think? Has anyone tried to measure engine power with regular and premium gas?
