Hi,
A thunder storm front moved through town and took out power:
Our natural gas powered, 16 kW generator fired up, waking me, and house power was restored in about 30 seconds. In the past, I would use a 1.1 kW inverter in our 2003 Prius to provide power for lights, TV, and either a window AC or the gas heater fan. The power was out for an hour.
The point is a vehicle-to-grid configuration needs to be at least functionally equivalent to an emergency generator:
A J1772 connector is frequently power limited to ~40 A @240 VAC, ~9.6 kW. The standard supports nearly double that, 80 A. Although the J1772 standard supports DC, it is pretty much used as an AC interface to the vehicle converter. The CCS-1 connector has dedicated DC power leads and typically handle up to 350 kW.
The AC-to-DC and DC-to-AC equipment should be located outside the car saving weight and allowing a bulky, high efficiency converter. It also needs to handle the safety interfaces to house and service line.
- SAFE - do not power the house service line when the grid fails
- automatic
- preserve lower limit - so the EV car can be used
- single home ~7.5 kW load
