Robert Lewis
So, a couple of interesting things happening with charging the Niro.
First, as noted in another thread, the car draws maximum amps the entire charging session. In my experience with the other EV's I've owned (a 2013 Leaf and a 2016 Volt), charging rate tends to gradually drop the closer the battery gets to 100% charge. This to to protect the battery over time. It also, probably, prevents excessive heat buildup as the battery reaches close to full capacity.
Second, I have noticed that on my L2 charger (charging at 24 amps), that the efficiency is not what I would expect from a L2. As an example, I started charging last night with right around 34% remaining charge. That means that I had right about 42 Kwh that needed to be added to the battery for a full charge. My EVSE reported that it took 48 kwh to completely charge the battery. That is a little shy of 90% efficiency. Typically, L2 charging is somewhere around 95% efficiency, I believe.
Third, the car does charge noticeably slower as it reaches 90% or so. In other words, the time to get from 80% to 90% is noticeably faster than the time it takes to get from 90% to 100%- although the EVSE is still reporting drawing the full current (24 amps) during that time.
So, I'm wondering if the Niro just handles charging a little differently in that it still draws max current the entire charging session, but as it approaches approx. 90% state of charge, perhaps some of that energy is being diverted to the battery cooling system, so the battery can still charge at a reasonable rate, but not heat up? Just floating a theory here, trying to explain the reason behind the perceived lower than normal efficiency, the readings from the EVSE showing max power draw throughout the charging session, and the fact that it takes noticeably longer to get from 90% to 100% charge.
