Hi folks, I saw a number of you post about the check engine light/system error that says Plug-in Charging Error, Power Limited (or something like that). Sounds like most of you had that problem while trying to charge (L2). We were driving and the error popped up close to home. There's still 39% (15 mi) supposedly remaining in battery power and we'd not been charging it. The OBD II reader reports fault code U0296 that brings up a generic error saying:
type: Network - Network Communication - ISO/SAE Controlled
description: Lost communication with AC to DC converter control module "A"
Anyone have resolution to this problem? We've turned the car off and on and few times and error persists. I hesitate to clear the fault code. Is this really something Honda will have to repair or does disconnecting negative battery terminal work to reboot and resolve the error?
